![]() | Home > Technical > Codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5124 ![]() ![]() ![]() |
dO YOU HAVE AFS lights where the beam moves ? |
joboco Member Since: 13 Sep 2021 Location: Scotland Posts: 24 ![]() ![]() ![]() |
So you have an afs warning in the dash or orange light stuck on ?
No warning light on the dash, of any kind. I'll check the headlights tomorrow as it's 60 mph winds and rain out just now. Just checked and no light dancing on auto or manual left or right. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
Thank you, I'll check that ASAP. Will the gap lld be the correct diagnostic for this? |
That is L/R's description of the fault code, if the Gap IID gave you that code it seems to me to be the most logical place to start, rather than "well it could be this, could be that" however I'm sure codes can be incorrect sometimes.
Cheers Col much appreciated. |
Thanks col.
What do you mean, you where guessing down the wrong route??? |
I thought it could be an afs problem.
