Home > Technical > Codes
joboco
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
Codes
Hi everyone, 2010 range rover sport L320 luxury. I've got a permanent code U0242-00: lost communication with the headlamp control module B.
Can anyone offer some advice as to best place to start looking for a fault.
TIA
Post #621356 Fri Jan 28 2022 4:26pm
dO YOU HAVE AFS lights where the beam moves ?
Post #621357 Fri Jan 28 2022 5:18pm
joboco
I'm not sure because it's never been out in the dark yet. Only had it 2 months and just fixing a few things. This is the last item on the fault codes to be fixed.
Can you tell from these pictures if they are AFS or not?
Post #621360 Fri Jan 28 2022 5:49pm
So you have an afs warning in the dash or orange light stuck on ?
Headlight should have AFS on the label if it is
Turn the lights when dark.
Do the lights do a dance
Or more accurately does one side dance Whistle
Post #621365 Fri Jan 28 2022 7:28pm
joboco
No warning light on the dash, of any kind. I'll check the headlights tomorrow as it's 60 mph winds and rain out just now. Just checked and no light dancing on auto or manual left or right.
Post #621366 Fri Jan 28 2022 8:04pm
Post #621370 Fri Jan 28 2022 9:26pm
joboco
Thank you, I'll check that ASAP. Will the gap lld be the correct diagnostic for this?
Post #621371 Fri Jan 28 2022 9:37pm
That is L/R's description of the fault code, if the Gap IID gave you that code it seems to me to be the most logical place to start, rather than "well it could be this, could be that" however I'm sure codes can be incorrect sometimes.
Post #621372 Fri Jan 28 2022 9:49pm
joboco
Cheers Col much appreciated.
Post #621373 Fri Jan 28 2022 9:51pm
Thanks col.
I was guessing down the wrong route
Post #621374 Fri Jan 28 2022 11:21pm
joboco
What do you mean, you where guessing down the wrong route???
Post #621377 Sat Jan 29 2022 6:40am
I thought it could be an afs problem.
But it sounds like a high beam assist problem.
Post #621380 Sat Jan 29 2022 9:09am
