Home > General > Parking sensors
Phil5197
United Kingdom 2007 Range Rover Sport TDV6 HSE Sumatra Black
Parking sensors
2011 sport, parking sensors not working, long bleep and switch light flashing, reader is saying front and rear sensor power circuit not valid, fuse 36 is okay?
Post #621329 Thu Jan 27 2022 4:58pm
One of the 8 sensors has failed short circuit.
You just have to find which one
I would remove the right headlight.
Disconnect the front park loom.
Clear all the codes
Put the car in reverse and park brake off Back to park
Read the fault codes.
You will get lots of front error codes but has the current code gone ?
If gone, fault probably at the front
If present fault probably at rear.
Remove appropriate bumper
ReConnect loom up.
Clear codes and remove one sensor at a time and check codes.
Or measure resistance between brown and black and remove a sensor at a time until it goes up significantly
Post #621333 Thu Jan 27 2022 7:28pm
Phil5197
Thanks mate,
Much appreciated
Post #621335 Thu Jan 27 2022 8:16pm
So what are the actual seven letter/number fault codes showing? as there are 45 different codes listed for the parking sensors/module and each individual sensor has at least 3 separate codes for it. Might help locate the fault easier.
Post #621346 Fri Jan 28 2022 4:56am
