Home > General > New brembo callipers
Page 3 of 4 <1234>
Nothing like that shield on mine, might actualy foul someting on the L320 so could proably leave it off without a problem.
Post #625750 Sat Jul 30 2022 8:22am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Yes thats what made me think if these could be off a FFRR and not a sport but if they’re the same after 2013 then thats a concern that shouldnt matter, I will take the shields off if theres no purpose for them.
Post #625751 Sat Jul 30 2022 8:24am
It's a Air Cooling Duct for the brakes, shown on the L405 & L494 but no used on the L320.
Post #625752 Sat Jul 30 2022 8:34am
jases4x4
Thats great Col, Thanks for looking, I will remove them, Just looking for best discs and pads and all the little replacement nuts etc.. hoping to get these fitted in the next few weeks.
Post #625753 Sat Jul 30 2022 8:38am
If it's not fouling anything like driveshaft, hub etc. can't really see it would do any harm if you did leave them on.
Post #625754 Sat Jul 30 2022 9:00am
Dave B
Backplates on the facelift with 360mm discs, are the same as those with 380mm discs, so don't waste your money, they are not cheap.
I bought a pair in case, and didn't fit them as wasn't needed.
If you still want to buy genuine new, drop me a PM.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #625757 Sat Jul 30 2022 12:00pm
jases4x4
Oh thats good to know Dave, Yes the TRW brakes i have on my 2010 v8 are 360mm so thats great just seen the price about £70 each! Do i need pad wear sensors?
These look tight not sure if the extra 20mm would fit in this space Dave are you certain?
Post #625758 Sat Jul 30 2022 12:04pm
As I said the part number for the backplates is the same for the facelift 3.0L TDV6 the TDV8 and the 5.0L S/C so they are all the same.
Post #625760 Sat Jul 30 2022 12:21pm
jases4x4
Yes you did Col, I can see why ppl just give them to garages and say you do all the work and fit them 😃 Still on that photo it doesnt look like theres 20mm gap for the bigger discs but im sure they must fit if they’re the same.
Post #625761 Sat Jul 30 2022 12:24pm
It won't be 20mm, it will be 10mm as the overall diam. Is 20mm difference.
Post #625762 Sat Jul 30 2022 12:27pm
Dave B
Don't forget, it's only a 10mm difference really, as the 20mm increase is for the diameter.
However, if you need to spend some money,
https://www.rrsport.co.uk/forum/topic58120.html
Sensors will also fit.
Post #625763 Sat Jul 30 2022 12:28pm
jases4x4
That explains it Dave, only 10mm each side and you say my existing wear sensors will fit into these callipers which is a result, Looks like i only need to source this kit that bolts the pads in now, Anyone know the name and does that central bolt come with it please?
Post #625764 Sat Jul 30 2022 1:19pm
jases4x4
Found this full kit on ebay, Not sure if the rear disks would fit my2010 sport aswell or are they different size for the rear l494 anyone know? This just easy option if i get this then its just the clips and bolt i need to secure the pads in.
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...635-2958-0
These are just front with ebc yellow pads
Post #625768 Sat Jul 30 2022 8:02pm
You may find the rear discs are different, as the L494 had a totally different park brake set up, the L494 being electrical the L320 being mechanical. In addition the first kit mentions 365mm diam. rear discs. The only L320 that had 365mm rear discs as standard was the 5.0L S/C I believe, so you may need to check the diam. of yours as they may well be only 350/355mm diam.
Post #625771 Sat Jul 30 2022 11:33pm
jases4x4
Looks like my2010 rrs mat have the 250mm rear discs Col, Powerfulluk hav ethis full kit with all the bits i might need, Noticed they do the Ebc ultimax 2 pads same as Maltings4x4 on ebay but they have some terrafirma discs so i think the britpart discs Powerfull uk sell mike be best option, Just not sure on these ebc ultimax 2 pads compared to the yellowstuff pads, Anyone know if theres much difference?
https://www.powerfuluk.com/rear-brake-upgr...10-13.html
Post #625783 Sun Jul 31 2022 10:18pm
Page 3 of 4 <1234>
