Home > Maintenance & Modifications > Retrofit heated steering wheel Facelift 2010 RRS
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Looking to retrofit a heated steering wheel on my 2010 facelift RRS and have seen a few Disco 4 heated wheels on Ebay that look identical to mine but obviously have the heat button.
I don't have any part numbers to compare so was wondering if anyone knows if they are a direct replacement?
Thanks in advance.
Post #620358 Fri Dec 31 2021 1:42am
It was a long time ago now that I changed one, but if I remember correctly the only D4 steering wheel part number that cross referenced to a Sport was from a 2012-2016 HSE Lux Disco, but am not saying none of the other wheels will not fit as not sure what the differences would be. If it helps as I was unsure I did end up buying a new wheel for the Sport which was LR023958 Ebony, Heated, Tiptronic, which is unfortunate because I do still have that steering wheel laid in the garage here as removed it prior to selling the car. I assume you are aware you will need the heated wheel version clock spring as well.
Post #620359 Fri Dec 31 2021 8:50am
Nilrem280
I did read that the clock spring was needed too, just working out if it's a worthwhile mod for the cost.
As always thanks for the info Col.
Post #620360 Fri Dec 31 2021 10:23am
Dave B
From experience, if the wheel has the same (white or black) horn symbol, it will fit.
My 2010 RRS and 2011 Disco 4 steering wheels are interchangeable.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #620362 Fri Dec 31 2021 1:00pm
Nilrem280
Thanks, Dave that's a big help.
Post #620371 Fri Dec 31 2021 6:01pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi, is it just the wheel and the clock spring? any wiring or coding?
Post #620531 Tue Jan 04 2022 11:50am
