![]() | Home > Maintenance & Modifications > Retrofit heated steering wheel Facelift 2010 RRS |
It was a long time ago now that I changed one, but if I remember correctly the only D4 steering wheel part number that cross referenced to a Sport was from a 2012-2016 HSE Lux Disco, but am not saying none of the other wheels will not fit as not sure what the differences would be. If it helps as I was unsure I did end up buying a new wheel for the Sport which was LR023958 Ebony, Heated, Tiptronic, which is unfortunate because I do still have that steering wheel laid in the garage here as removed it prior to selling the car. I assume you are aware you will need the heated wheel version clock spring as well.
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
I did read that the clock spring was needed too, just working out if it's a worthwhile mod for the cost.
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
From experience, if the wheel has the same (white or black) horn symbol, it will fit.
Thanks, Dave that's a big help.
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Hi, is it just the wheel and the clock spring? any wiring or coding? |
