Home > Maintenance & Modifications > Fuel Pre-Heat problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. VIN SALLSAA146A934562. Having problems with excessive diesel being burned and clouds of smoke. A replacement would cost £800.00 and I understand parts are not available. If the problem persists would it be safe to unplug it or perhaps take out the fuse? Andrew Kennedy
Post #619520 Fri Nov 26 2021 10:12am
gogsy1956
Parts are available,,, although not very cheap. I had issues with mine leaking which was causing excessive smoke so I unplugged the two connectors,, taking fuses out was causing other issues, unless I pulled the wrong fuse!. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #619527 Fri Nov 26 2021 3:51pm
riverblanche
Hi,
dont forget the FBH is not just about getting you warmer quicker its main function is getting and Keeping the engine up to operating temp quicker, many dont notice or realise that the the FBH can operate a number of times during a journey if slow moving or frequent stopping and starting, so a none functioning FBH will also potentially use more fuel as the engine is not up to temp
As said they can be stripped and cleaned but excess fuel may be the FBH fuel pump ?
if you want to get serious about it there is has its own topic over on D3 Whistle
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #619537 Fri Nov 26 2021 7:21pm
andrew kennedy
Pre Heater problem
Thank you both for the info!! I have found a replacement for a price of £65 so I'm very happy about that. Andrew Kennedy
Post #619560 Sat Nov 27 2021 3:46pm
