![]() | Home > Maintenance & Modifications > Fuel Pre-Heat problem |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Parts are available,,, although not very cheap. I had issues with mine leaking which was causing excessive smoke so I unplugged the two connectors,, taking fuses out was causing other issues, unless I pulled the wrong fuse!. 2010 RRS, TDV8
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 346 ![]() ![]() ![]() |
Thank you both for the info!! I have found a replacement for a price of £65 so I'm very happy about that. Andrew Kennedy |
