Home > Faults & Fixes > Air flow meter 5l SC help
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Hi guys, having a repeated issue with my car, obd says air flow sensor issue.
Car keeps hunting when doing a constant speed with a light touch on the accelerator. It's fine under full foot down mode or slowing down.
I was advised by the supplying dealer to clean the sensors and this worked for 8 weeks, but has now come back again. Cleaned them again and it seems to have cleared the issue.
What I would like to know is there a reason for the sensors getting dirty or is it simply a matter of wear and tear?
If it is wear and tear any recommendations as to a suitable supplier of OEM quality parts? Anyone have the part number?
TIA
Post #619444 Tue Nov 23 2021 6:29pm
Ken 153
Anyone?
Post #619621 Mon Nov 29 2021 7:01pm
Ken 153
MAFS534-OE anyone confirm that this is the correct part number? Also are they the same on both intakes as they "look" different.
Are they any cheaper from Jaguar?
TIA
Post #620311 Tue Dec 28 2021 6:43pm
They are both the same, just screwed in a different position. Rimmer Brothers have some cheap Chinese Specials at 80.00 quid each, special being they probably last as long as it takes to remove them from the box.
LR012073
FoMoco 7G9N-12B 579-AB
Denso DMA-0103
Post #620318 Tue Dec 28 2021 9:49pm
Ken 153
Thanks Col.
Post #620320 Tue Dec 28 2021 10:51pm
Ken 153
Col wrote:
LR012073
Denso DMA-0103
Which is the best to go for???
Post #620321 Tue Dec 28 2021 10:53pm
You'll probably find that the LR and FoMoCo ones are just re-branded Denso.
I'd just get the Denso one, probably the cheapest as well Thumbs Up --
Post #620323 Wed Dec 29 2021 7:15am
Go for the Denso ones £120.00 each, same thing in a pretty L/R branded box will cost you £240.00.
Post #620324 Wed Dec 29 2021 8:11am
Ken 153
Thanks guys, got a pair @ £117.50 each. Thumbs Up Thumbs Up
Post #620326 Wed Dec 29 2021 1:56pm
Ken 153
These arrived today, 5 minutes to fit them, ran the GAP to clear all faults, then took her for a test drive.
I was totally amazed at the difference in the driving experience I had.
Gear change smoother, throttle response better, no hunting or indicision in gear choice or wanting to take off like a rocket every time you touched the throttle.
If you would have told me that spending £240 would change the car this much, I wouldn't have believed you!
Thanks for all your help guys.... Just what forums should be for Bow down Thumbs Up
Post #620617 Thu Jan 06 2022 7:11pm
