![]() | Home > Faults & Fixes > Air flow meter 5l SC help |
| Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189
Anyone? |
MAFS534-OE anyone confirm that this is the correct part number? Also are they the same on both intakes as they "look" different.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
They are both the same, just screwed in a different position. Rimmer Brothers have some cheap Chinese Specials at 80.00 quid each, special being they probably last as long as it takes to remove them from the box.
Thanks Col. |
Which is the best to go for??? |
| naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210
You'll probably find that the LR and FoMoCo ones are just re-branded Denso.
Go for the Denso ones £120.00 each, same thing in a pretty L/R branded box will cost you £240.00.
Thanks guys, got a pair @ £117.50 each. |
These arrived today, 5 minutes to fit them, ran the GAP to clear all faults, then took her for a test drive.
| All times are GMT |
