![]() | Home > Maintenance & Modifications > Rhino ramps, or alternatives. |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi i bought these find them ideal for my RRs I have used them diffs ,transfer box and other things underneath and bern fine.One thing I would say is just be careful when going up onto flat section and take your car up slowly and keep checking as you get near end stop . |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Thats the sort of thing I was thinking about thanks. Am I right in thinking they have a 21cm lift? |
Hi 21inch is the total height at the very top of tyre stop,usable flat area where your wheel would sit is 18inch.When I use mine I put it in off road height and use low range to go up them. |
The RhinoGear seems to have 281mm to the top so should give a bit more lift.
Cool and they seem to be at a good price also, remember for your diffs put the specific volumes in as per LR SPECS I used a big syringe to fill the diffs back up worked a treat.With transfer box get a new copper washer for fill plug and when the car is the on flat ground you should just have a dribble coming out fill plug area. |
Thanks for that, yep I've been reading up on the procedure. I will have to dig out my old Draper syringe that I got when I did my D1 a long time ago |
Not sure if you have a link to these. |
