Home > Maintenance & Modifications > Rhino ramps, or alternatives.
Oldandconfused
I am considering a set if ramps so I can change diff and transfer box oils on my drive and was wondering what people can recommend.
I have a gravel drive so am a bit concerned about using a jack and stands even with blocks under them and can't work out how to lift the front or back in one go, hence ramps.
Any thoughts appreciated.
Post #619367 Sun Nov 21 2021 1:18pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi i bought these find them ideal for my RRs I have used them diffs ,transfer box and other things underneath and bern fine.One thing I would say is just be careful when going up onto flat section and take your car up slowly and keep checking as you get near end stop . Thumbs Up Thumbs Up
DURHAND 1 Pair Heavy Duty 5 Ton Plastic Garage Workshop Car Service Ramps Lifting Automotive Vehicle Portable Low Clearance
https://www.amazon.co.uk/dp/B07MBXRSXV/ref...&psc=1
Post #619382 Sun Nov 21 2021 4:46pm
Oldandconfused
Thats the sort of thing I was thinking about thanks. Am I right in thinking they have a 21cm lift?
Post #619389 Sun Nov 21 2021 5:46pm
Iomegas
Hi 21inch is the total height at the very top of tyre stop,usable flat area where your wheel would sit is 18inch.When I use mine I put it in off road height and use low range to go up them. Thumbs Up
Post #619393 Sun Nov 21 2021 7:10pm
Oldandconfused
The RhinoGear seems to have 281mm to the top so should give a bit more lift.
https://www.amazon.co.uk/RhinoGear-11912AB...p;qid=1637
Post #619394 Sun Nov 21 2021 9:13pm
Iomegas
Cool and they seem to be at a good price also, remember for your diffs put the specific volumes in as per LR SPECS I used a big syringe to fill the diffs back up worked a treat.With transfer box get a new copper washer for fill plug and when the car is the on flat ground you should just have a dribble coming out fill plug area. Thumbs Up
Post #619395 Sun Nov 21 2021 10:15pm
Oldandconfused
Thanks for that, yep I've been reading up on the procedure. I will have to dig out my old Draper syringe that I got when I did my D1 a long time ago
Post #619399 Mon Nov 22 2021 9:41am
Iomegas
Not sure if you have a link to these. Thumbs Up
https://www.rangerovers.net/threads/2010-2...de.330662/
Post #619403 Mon Nov 22 2021 10:48am
Oldandconfused
Post #619411 Mon Nov 22 2021 2:47pm
