Home > Technical > Rear Seatbelts Issue
Lynchy
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
So, I've got a couple of child seats in the back of the RRS.
More often than not now, the belt locks up halfway through getting it clicked in, and wont pull out any further. What's more annoying is it has to be retracted all the way to the start before being able to be pulled again, which requires me to remove the car seat each time so that the belt can fully retract.
Anybody had this issue?
Post #619358 Sun Nov 21 2021 9:44am
I think the belts are too cleaver for their own good, having a memory.
If you slowly pull them all the way out, and then run them back in, in should reset them.
Maybe in the owners manual
Post #619359 Sun Nov 21 2021 10:10am
Lynchy
Thanks mate. Dont have an OM so any help is appreciated. Thanks again.
Post #619402 Mon Nov 22 2021 10:12am
Grimble
Use one of these plastic clip thingys for sealing food bags to stop it retracting when you pull it fully out. It will keep it in place while you thread it through the child seats.
Doesn't damage the belt and prevents fury also. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #619463 Wed Nov 24 2021 5:30pm
Re: Rear Seatbelts Issue
It's a design feature and covered in the owner's manual although it sounds like yours is working in reverse:
Perhaps it's not retracting quite far enough to release the locking mechanism? 2012 SDV6 - it's missing a couple of cylinders
Post #619515 Thu Nov 25 2021 10:11pm
aaronjb
Mine are like that - they are stuck in 'large item mode'.. I've never been able to get them to return to normal operation :/ 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619523 Fri Nov 26 2021 11:26am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
i have a similar issue with mine, though mostly the center seat. When I drop the rear seat back to load a big item and put it back up again, the mechanism locks and goes bar taut, and I can't feed it back to unlock it.
I have resorted to leaving it permanently done up, then undo it, when moving the seats. Sometimes the "simple is beautiful" philosophy is lost on manufacturers.
Post #619528 Fri Nov 26 2021 4:37pm
Lynchy
Can this be turned off? This large item setting on the Belts. . . Its doing my head in. It locks up when kids try to betl up all the time. Since theres a car seat in for the kids, the belt has to come out all the way, and if they let a little back in, it starts that stupid 'clicking' for large item mode.
Post #620102 Sun Dec 19 2021 12:11am
