![]() | Home > General > 2007 RRS TDV8 Vs TDV6 |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 ![]() ![]() ![]() |
Hello all,
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
I bought my 2007 TDV8 two years ago very happy with it, have found a great independent to look after it . It came with a very comprehensive service history which I was told is vital , my indie reckons that oil changes are extremely important in prolonging the life of the turbos & also letting the engine idle for about a minute before turning off after a journey. Fuel consumption varies between 20-30 mpg the lower is when I am towing our twin axle caravan. Have had all the central locking actuators replaced in the doors this seems a very common fault, worth checking to haggle the price down, good luck with your search. I read on this forum the problems with the V6s especially the crankshaft issues which swayed me towards the V8. |
Thanks for the replies.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
Maintenance is basically the same as the TDV6 excepting the TDV8 doesn't need a belt change.
Do all TDV8 have the dynamic response?
All TDV8 had dynamic response.
Thanks for your responses.
