Home > Technical > Eureka moment.
Devon Z
Eureka moment.
Long story short always thought my 2.7 was very sluggish around 1500rpm and that the turbo doesn’t kick in, well after taking the tin shed down to Cornwall this lack of power was more prevalent!
Doing some research on Disco3 I found that this issue was cured in some cases by unplugging the electrical plugs on the EGR valves? (Mine are blanked) Well nothing ventured I thought? Well what a transformation, gone is the 1500rpm black hole of no power, hesitation and seeming indecision from engine and gearbox, she now pulls hard, smooth and quieter it’s like driving a different car.
Read codes and obviously still got EGR valve bank A but the speed control error has gone and replaced with EGR temp sensor C low voltage.
So far well chuffed all round😃😃 Steve
1998 Volvo V70 R auto FWD, Back on the road again.
Post #617947 Wed Oct 06 2021 8:54pm
Ken 153
United Kingdom 2010 Range Rover Sport Supercharged HSE Galway Green
Sounds like a result... Thumbs Up
Post #617949 Wed Oct 06 2021 9:26pm
I guess this is because you haven't removed the butterfly in the intake Y ?
Though I think you have a better solution
Post #617960 Thu Oct 07 2021 12:36pm
Stevepd
When I had my EGR blanked the butterfly was doctored. Today I came across the below on the disco3 forum about the 2.7 map sensor. I removed mine today at work (10 mins tops) and mine was a little gunky. I cleaned it and made a note of the mileage and willl check again in a few k. Just a thought to check.
https://www.disco3.co.uk/forum/topic64159.html 2006 2.7 TDV6 HSE in Cairns Blue.
Post #617963 Thu Oct 07 2021 5:14pm
Devon Z
Butterfly removed and map sensor cleaned which had only made a minor improvement but nowhere had I read anything about unplugging the EGR’s until recently. Steve
Post #617967 Thu Oct 07 2021 10:27pm
Stevepd
Steve ,
Have you got a link to where you read please.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #617979 Sat Oct 09 2021 8:45am
Devon Z
I’ll try and find it again. Steve
Post #618021 Sun Oct 10 2021 11:38pm
Devon Z
Here it is, mentioned on the last page.
https://www.disco3.co.uk/forum/technical-d3-vf2.html Steve
Post #618022 Sun Oct 10 2021 11:47pm
