![]() | Home > Technical > Eureka moment. |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 189 ![]() ![]() ![]() |
Sounds like a result... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
I guess this is because you haven't removed the butterfly in the intake Y ?
When I had my EGR blanked the butterfly was doctored. Today I came across the below on the disco3 forum about the 2.7 map sensor. I removed mine today at work (10 mins tops) and mine was a little gunky. I cleaned it and made a note of the mileage and willl check again in a few k. Just a thought to check.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
Butterfly removed and map sensor cleaned which had only made a minor improvement but nowhere had I read anything about unplugging the EGR’s until recently. Steve
Steve ,
I’ll try and find it again. Steve
Here it is, mentioned on the last page.
