![]() | Home > In Car Electronics > Steering wheel left side buttons inoperative. L494 |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
Try disconnecting the battery for ten minutes and then reconnect…
djm1502 Member Since: 05 Oct 2021 Location: Wirral Posts: 3 ![]() ![]() |
Cheers. That won't have any other consequences will it? |
It shouldn’t do… we had the same issue … it was cured by the battery disconnect…
Cheers. I'll try it. Also saw a post on a North America RR website saying the left side buttons for this vehicle were part of a recall. If you google LTB00584NAS5 you can see it. Is there any way to see if this is also part of the RR UK service website? I think its maybe a known problem but I don't know how to make the case to the local RR main agent (since end of warranty its been serviced by a LR independent garage). Is there any UK website that has this detail you know of? |
Josh492@hotmail.co.uk Member Since: 31 May 2025 Location: Pembrokeshire Posts: 7 ![]() ![]() ![]() |
Did you ever fix the issues ive tried everything now! |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 317 ![]() |
Hi very common issue , can try the battery disconnect or just replace them, I bought a new set from ebay to replace mine. |
steveo200 Member Since: 01 Oct 2025 Location: Lancashire Posts: 7 ![]() ![]() |
I am chasing this problem, left hand controls not working.
Disconnect battery for a few mins and this usually sorts its out.
Tried this and still the same.
