Home > In Car Electronics > Steering wheel left side buttons inoperative. L494
djm1502
Apologies if this question has been listed here already but I can't see anything similar.
My RRS L494 2014 now doesn't work the left side steering wheel controls. Very occasionally one key press (eg vol up or down) belatedly brings up a different function (eg phone) but not reliably. Anyone had this and any ideas for a fix?
Post #617920 Tue Oct 05 2021 8:04pm
Farmer Chalk
Try disconnecting the battery for ten minutes and then reconnect…
You’ll find it should reset…
Post #617922 Tue Oct 05 2021 10:12pm
djm1502
Cheers. That won't have any other consequences will it?
Post #617990 Sat Oct 09 2021 6:06pm
Farmer Chalk
It shouldn’t do… we had the same issue … it was cured by the battery disconnect…
Worked perfectly afterwards… hoping it works for you!
Post #617995 Sat Oct 09 2021 9:32pm
djm1502
Cheers. I'll try it. Also saw a post on a North America RR website saying the left side buttons for this vehicle were part of a recall. If you google LTB00584NAS5 you can see it. Is there any way to see if this is also part of the RR UK service website? I think its maybe a known problem but I don't know how to make the case to the local RR main agent (since end of warranty its been serviced by a LR independent garage). Is there any UK website that has this detail you know of?
Post #618050 Tue Oct 12 2021 12:24pm
Josh492@hotmail.co.uk
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Did you ever fix the issues ive tried everything now!
Post #649241 Sat Aug 02 2025 2:53pm
Post #649242 Sat Aug 02 2025 2:54pm
Karlp606
Hi very common issue , can try the battery disconnect or just replace them, I bought a new set from ebay to replace mine.
Post #649283 Tue Aug 05 2025 9:53am
steveo200
I am chasing this problem, left hand controls not working.
Initially GAP showed a fault with the left hand control, I swapped the left hand buttons, cleared the fault and rescanned.
It has now swapped to the right hand control being at fault.
I have swapped the right hand control for another, but the left is still not working.
I have checked the steering wheel loom for continuity and taken all the electrical connectors off and reseated.
All I can think now is maybe the clockspring, or a short somewhere else?
Any idea?
I may have to give up on this and get it booked in to my local indy.
Post #650070 Sat Oct 04 2025 10:51am
Karlp606
Disconnect battery for a few mins and this usually sorts its out.
It’s a strange fault linked to the actual control unit behind the screen. The buttons are sending a signal but the main brain isn’t operating.
Another weird RRS issue!
Post #650076 Sat Oct 04 2025 12:24pm
steveo200
Tried this and still the same.
It's just had a new main battery on, battery was disconnected for over an hour.
Post #650077 Sat Oct 04 2025 12:31pm
