Home > General > Brake line burst |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Just a short pipe between the 2 rear flexis.
Sun Sep 26 2021 8:13pm |
Thanks, after quite a bit of searching I've found them, part no's LR021678 & LR021679 left & right. Earlier on I never got as far as removing the wheel, from that zoomed in photo I thought they were plastic pipes but nope, metal, which makes sense as more likely a corrosion burst.
Sun Sep 26 2021 10:05pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
If those have gone check the metal pipes beyond …ie. under the car in front of the rear wheels..
Mon Sep 27 2021 9:51pm |
Isnt it recommended flexi hoses are changed every 7 years on a service schedule 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Sep 28 2021 8:12am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Recommended brake fluid every 3 years and flex brake pipes every 6 years, but I bet there ain't many that get done.
Tue Sep 28 2021 8:44am |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 224 |
Slightly different vehicle, but I have just changed the original flexible brake lines on my 23 year old motorcycle. No perishing or apparent weakness in the rubber on the old ones, just did it as I was refurbing the calipers and it seemed an opportune time. Have fitted braided connections which should certainly see both me and the bike out. Excellent service from Goodridge. RRS HSE Dynamic SDV6 2014
Tue Sep 28 2021 12:01pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
I've had the front and rear flexis changed on mine, not because of any obvious degradation of the rubber but because the metal connectors were pretty rusty. |
Tue Sep 28 2021 5:57pm |
I looked into this a few years back when I changed mine and did look to see if anyone made braided lines for a RR Sport including Goodridge, and to my suprise I couldn’t find anyone making them 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Tue Sep 28 2021 7:37pm |
Thanks folks, it does sound sensible to replace the flexi's especially if the central metal pipe is being replaced anyway, and as long as the inner flexi comes away from the other end metal lines then it'd likely be an easier task anyway with not having to tryaand split corroded fittings, just cut.
Tue Sep 28 2021 9:14pm |
I think a company called HEL will make to order, just give dimensions and end connection type. Its just a thought, but why arent all brake lines flexible from new? No corrosion and so much easier to replace. The additional cost (if any) on a vehicle that already costs mega-bucks would be negligible. RRS HSE Dynamic SDV6 2014 Nemo mortalium omnibus horus sapit |
Wed Sep 29 2021 10:52am |
I set to this brake pipe removal today (garage had a long wait list and I need the RRS on the road) and I found something I thought quite strange - the pipe had burst at both ends. I say strange as I can undertand it being corroded at both ends but surely one end would burst first, then the pressure wouldn't be as high to push through any other bit? Anyway I crimped/cut the pipe near the nuts and a 6 point socket was perfect to get it out thankfully with no drama, this surprised me with state it looked even after a wire brush/release fluid soak.
Wed Sep 29 2021 9:31pm |
Don’t forget to inspect the metal lines running up to the flexis in front of the rear wheels… they are also very prone to corroding! Particularly near the mounting clips where the lines are clipped to the body… |
Wed Sep 29 2021 9:55pm |
Thanks Farmer Chalk, I must have a better look at the rest of the brake lines once I can get over my inspection pit, what you say about the sponge stuff holding water makes sense. Currently I've a beautiful MF135 sitting over the pit surrounded by a heap of stuff which was a bigger task to clear than I have time for at the moment so I've currently got the RRS jacked up on the drive.
Wed Sep 29 2021 10:12pm |
Sounds like you are looking at the right pipe. It you get an opportunity to spray them with under seal … it’s definitely the pipe that runs back from the engine bay. |
Thu Sep 30 2021 9:33pm |
