Home > In Car Electronics > Phone setup, no manuals.
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Probably not a new post , but it seems like a member called Bodsy has all the answers after some posts .
I have just purchased an RR Sport after owning a VOGUE and no manuals!
My phone buttons on the steering wheel says no phone fitted!
My phone an ANDROID Samsung detects the Landrover .....and blank . Can anyone help, please.
RRS 2007
Cheers Pat
Post #617692 Sat Sep 25 2021 7:31pm
Shaun W
Just had the same issue, but apple. I went through the Bluetooth search, select Handsfree/Landrover and then pair.
The code for my Bluetooth pairing code is 2121.
Once I put the code in the phone paired and now shows and I can access the phone via the controls on steering wheel and touch screen.
Post #617695 Sat Sep 25 2021 8:26pm
alfapat
Have to try that code, I get the Land rover pair but no code.
Should add the phone picks up the Land Rover pair .
Just had a thought , I have had a read of our Freelander book and its the same set up , but it says with ignition on not motor running , I will be back!
Post #617698 Sun Sep 26 2021 9:08am
alfapat
Thanks that code worked.
Post #617719 Sun Sep 26 2021 6:18pm
Shaun W
Can you make phone calls?
I can’t, it dials then disconnects. Haven’t tried incoming calls yet.
Post #617731 Sun Sep 26 2021 10:27pm
Shaun W
It’s gone back to the garage to get some niggles sorted, I’ve asked them to look at it for me as it wouldn’t connect to the mechanics phone either.
Post #617738 Mon Sep 27 2021 2:50pm
alfapat
I think it connects on mine , it accidently dialled local Arnie CLark ! but cut the call in time, that's fine but the volume was far too high , is there a setting for that , sorry no books as I said.
Post #617742 Mon Sep 27 2021 7:22pm
Just turn the vol knob down while making a call. And it will remember the phone setting.
Similar with nav announcements. Adjust vol while its talking. Got to be quick Laughing
And don't turn it all the way down !!!!
Post #617744 Mon Sep 27 2021 7:40pm
alfapat
OK Thats great thanks for the tip.
Post #617801 Fri Oct 01 2021 10:13am
