Home > Faults & Fixes > Suspension warning and cruise control
Rodosray
Hi please can anybody help, I put my red tdv8. 2010. Into. Just Tyres for 4 new tyres .
And after collecting all that keeps coming up on dash is. Normal road height only, and No Forward Alert and also no Cruise Control.
I have read that if car wasn’t put into a certain mode, this has now confused the suspension and it will keep happening until it is
Reset .
If anyone can help I would extremely grateful.
Rodosray
Post #617515 Tue Sep 21 2021 7:07am
Oldandconfused
If you mean Tight Tolerance Mode, that's when wheel alignment is carried out, which is unnecessary for changing tyres as nothing is adjusted (or did you have an alignment carried out?).
It may well be that one of your height sensors have been disturbed, again not something you would expect from a competent tyre fitter but that doesn't mean it wasn't.
Did they use a 2 post lift or jack under the car? There is a plastic (i.e not load bearing) cover over the air suspension compressor mid car on the nearside next to the chassis rail, and if they have jacked on that the compressor will be damaged.
Or, they could have left a door open and an already weak battery could have been discharged enough to throw faults. These cars are very sensitive to a low battery charge and it may be a good charge will clear the fault messages.
If you hang about on here long enough, you will get the message that you need the stored fault codes reading for a definitive answer. Many of us have/have access to a code reader because they are really complicated beasts and without codes we are at best making informed guesses.
Post #617518 Tue Sep 21 2021 8:22am
Rodosray
Many Thanks for your help, they actually jacked it up on 3 corners first and then just the offside rear and since I left them the advisers are normal height only, forwards alert not working and also no cruise control.
Garage put on computer but no error codes came up.
I start car drive for 2 minutes and then I get the message
Post #617524 Tue Sep 21 2021 10:17am
Oldandconfused
From memory, normal road height only was a message when my suspension compressor gave up the ghost. I didn't have access to a code reader then so had to be guided by the indi I used, and a new one fixed that. Strange it takes a couple of minutes to flash up, mine did it almost immediately. I'm surprised there are no error codes as the car is clearly identifying faults and they should be stored until cleared. When you say garage, do you mean a LR specialist, or was it the tyre fitters. Not all readers will read all the codes, hence why people have their own (when you have a minute, have a search for code readers GAPIId/Autel etc). I don't know enough to judge if a problem with a height sensor would throw up the other 2 faults, hence the need for fault codes.
If it's a problem with the battery, it may be worth testing it and alternator.
Post #617526 Tue Sep 21 2021 11:52am
Kot
Agree with Oldandconfused can only be caused by your tyre fitters. Also warning comes up after 2 mins as compressor cannot keep up with the loss of air and doesn't make the pressure switch.
It will be an air problem, you will have a leak somewhere. Buy the cheap Autel AP200 OBD2 Bluetooth or similar, the codes will confirm.
I lost same controls, fortunately was under warranty (LR assist fixed on driveway) turned out to be cracked air suspension silencer valve attached to compressor. Get the soapy water out lol
Post #617527 Tue Sep 21 2021 12:12pm
