| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Suspension warning and cruise control |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | If you mean Tight Tolerance Mode, that's when wheel alignment is carried out, which is unnecessary for changing tyres as nothing is adjusted (or did you have an alignment carried out?).
|  Tue Sep 21 2021 8:22am |
| Rodosray Member Since: 06 Oct 2020 Location: East Sussex Posts: 2      | Many Thanks for your help, they actually jacked it up on 3 corners first and then just the offside rear and since I left them the advisers are normal height only,  forwards alert not working and also no cruise control.
|  Tue Sep 21 2021 10:17am |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | From memory, normal road height only was a message when my suspension compressor gave up the ghost. I didn't have access to a code reader then so had to be guided by the indi I used, and a new one fixed that. Strange it takes a couple of minutes to flash up, mine did it almost immediately. I'm surprised there are no error codes as the car is clearly identifying faults and they should be stored until cleared. When you say garage, do you mean a LR specialist, or was it the tyre fitters. Not all readers will read all the codes, hence why people have their own (when you have a minute, have a search for code readers GAPIId/Autel etc). I don't know enough to judge if a problem with a height sensor would throw up the other 2 faults, hence the need for fault codes.
|  Tue Sep 21 2021 11:52am |
| Kot Member Since: 07 Jan 2021 Location: UK Posts: 92  |
 Agree with Oldandconfused can only be caused by your tyre fitters. Also warning comes up after 2 mins as compressor cannot keep up with the loss of air and doesn't make the pressure switch. It will be an air problem, you will have a leak somewhere. Buy the cheap Autel AP200 OBD2 Bluetooth or similar, the codes will confirm. I lost same controls, fortunately was under warranty (LR assist fixed on driveway) turned out to be cracked air suspension silencer valve attached to compressor. Get the soapy water out lol | ||
|  Tue Sep 21 2021 12:12pm |
| Posting Rules
