Home > General > Loss of power
Wayneclarke
Loss of power
So driving home today went to pull away from a roundabout and the car had no power then picked up speed almost felt like i was trying to pull away in 5th gear, black smoke out the back when i tried to put my foot down. idle revs are fine no lights on the dash!!! any ideas?
Post #611849 Wed Mar 24 2021 8:29pm
1richard1
Turbo hose may have a split.
Post #611850 Wed Mar 24 2021 8:33pm
Wayneclarke
whats the best way to check?
Post #611851 Wed Mar 24 2021 8:42pm
OvalAutos
Get somebody to read the codes first before guessing. Joe
Post #611859 Thu Mar 25 2021 8:32am
Wayneclarke
there was no codes or no lights on the dash, idled fine just no power when i pulled away after 2500rpm it seemed ok. I've dropped the car at my local garage now as i couldn't see anything obvious. i will update when i hear back from them
Post #611868 Thu Mar 25 2021 11:45am
Eaters
When I had a loss of power caused by a split top turbo hose there was no smoke. This sounds a bit more serious than that. The way forward is to get the codes read. Hope that "local garage" is a specialist LR one or they may not get you much further forward. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #611933 Fri Mar 26 2021 4:09pm
Wayneclarke
Just spoke to the garage there still working on it, they are saying one of the egr valves is stuck
Post #611939 Fri Mar 26 2021 5:15pm
Wayneclarke
so drivers side egr was totally shot, falling apart so the garage made up some blanks and blanked the egr off. car is now running fine
Post #611952 Fri Mar 26 2021 8:33pm
1richard1
A good result not to expensive.
Post #611960 Sat Mar 27 2021 8:00am
Wayneclarke
yeah great result the garage has been amazing over the 7 years I've had my car, 100% trust them.
Post #611968 Sat Mar 27 2021 9:42am
