![]() | Home > General > Loss of power |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Turbo hose may have a split. |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
whats the best way to check? |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Get somebody to read the codes first before guessing. Joe |
there was no codes or no lights on the dash, idled fine just no power when i pulled away after 2500rpm it seemed ok. I've dropped the car at my local garage now as i couldn't see anything obvious. i will update when i hear back from them |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
When I had a loss of power caused by a split top turbo hose there was no smoke. This sounds a bit more serious than that. The way forward is to get the codes read. Hope that "local garage" is a specialist LR one or they may not get you much further forward. Robin
Just spoke to the garage there still working on it, they are saying one of the egr valves is stuck |
so drivers side egr was totally shot, falling apart so the garage made up some blanks and blanked the egr off. car is now running fine |
A good result not to expensive. |
yeah great result the garage has been amazing over the 7 years I've had my car, 100% trust them. |
