![]() | Home > General (L494) > Extended suspension height ? HELP |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
could be a blocked compressor cone filter,
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426 ![]() ![]() |
It seems to be a intermittent fault as hasn’t done it this morning. Is the cone filter something that can be cleaned or changed and if so where is it located ? 2019 4.4 SDV8 Autobiography Velocity blue.
have you read the ? |
Plugged it in and no fault codes. 2019 4.4 SDV8 Autobiography Velocity blue.
sorry, lost a word there..
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 41 ![]() ![]() |
I have this on mine, sometimes with automatic access height instead of lowering the car it would raise it right up in the air instead. I've turned off auto access height now and just lower it manually as I'm pulling up somewhere |
sorry no I haven't. Will have a read when I get 5 mins 2019 4.4 SDV8 Autobiography Velocity blue. 2017 SVR. SVO Scafell grey Ebony interior. Gone 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
I have noticed it only does it if your on any kind of incline. If the ground your parking on is flat then everything is as normal. 2019 4.4 SDV8 Autobiography Velocity blue.
That link you posted seems to be for the old style sport, is it the same for the L494? |
Anyone have a fix for this on an l494? Or is the only fix to get a replacement air compressor fitted? |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1921 ![]() ![]() |
Almost certainly. ![]() 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Ok found it didn't look blocked or anything, long shot but whilst I was looking around down there I found this was unplugged. Any ideas what it's for?
