Home > General (L494) > Extended suspension height ? HELP
Smarttech
The last few days my car has been going from access height to extended height after you switch it off and open the door.
Anyone know what might cause this ? I have plugged it in and no fault codes coming up ! 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #611488 Mon Mar 15 2021 7:46am
scarey
could be a blocked compressor cone filter,
https://www.fullfatrr.com/forum/topic23038.html
Post #611489 Mon Mar 15 2021 9:31am
Smarttech
It seems to be a intermittent fault as hasn’t done it this morning. Is the cone filter something that can be cleaned or changed and if so where is it located ? 2019 4.4 SDV8 Autobiography Velocity blue.
Post #611490 Mon Mar 15 2021 9:50am
scarey
have you read the ?
Post #611494 Mon Mar 15 2021 10:20am
Smarttech
Plugged it in and no fault codes. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #611495 Mon Mar 15 2021 10:27am
scarey
sorry, lost a word there..
have you read the link i posted?
Post #611500 Mon Mar 15 2021 11:38am
Laurie100uk
I have this on mine, sometimes with automatic access height instead of lowering the car it would raise it right up in the air instead. I've turned off auto access height now and just lower it manually as I'm pulling up somewhere
Post #611502 Mon Mar 15 2021 12:29pm
Smarttech
sorry no I haven't. Will have a read when I get 5 mins 2019 4.4 SDV8 Autobiography Velocity blue.
Post #611503 Mon Mar 15 2021 12:33pm
Smarttech
I have noticed it only does it if your on any kind of incline. If the ground your parking on is flat then everything is as normal. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #611504 Mon Mar 15 2021 12:34pm
Laurie100uk
That link you posted seems to be for the old style sport, is it the same for the L494?
Post #611505 Mon Mar 15 2021 12:36pm
Laurie100uk
Anyone have a fix for this on an l494? Or is the only fix to get a replacement air compressor fitted?
Post #616756 Mon Aug 23 2021 2:21pm
jimbg
Almost certainly. Thumbs Up 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #616758 Mon Aug 23 2021 3:25pm
Laurie100uk
Ok found it didn't look blocked or anything, long shot but whilst I was looking around down there I found this was unplugged. Any ideas what it's for?
Post #616765 Mon Aug 23 2021 5:51pm
