![]() | Home > Maintenance & Modifications > "Vehicle lean when cornering" |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
Panic over, the garage managed to put it on a code reader and the lateral accelerometer needed recalibrating, a bit of a relief and the car is now back home |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
The what needed calibrating!? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
There's are five off them in total I think one in the middle at the front and one on the left and one on the right at the rear, also a couple more one behind headlining by the interior light pod and one by the dynamic valve block under the o/s of car, not sure which does what though. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
Two accelerometers - one up by the rear view mirror and one on the chassis rail below the driver (near the dynamic response valve block). There's also a yaw sensor on the cabin floor below the centre console.
Note: this is for the L320 which uses the accelerometers for dynamic response (active anti roll bars). The L494 has additional accelerometers as Col mentions with two at the front (left and right) and one at the rear. These are for the adaptive dynamics - the active dampers fitted to the L494. The L494 also has the two mentioned for the L320 for its own active anti roll bars, giving 5 in total. Complicated wee beasties! Tell a lie ![]() So original L320 has two accelerometers, facelift L320 and the L494 have 5 but they're in different places. Complicated indeed! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Location off them on the L320 with active suspension. Bedtime reading if anybody really really want's to read all about. |
I hadn't heard of them either before today, just pleased it was a simple fix. |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Col I am very mpressed with your knowledge on RRSs....the majority of questions I have seen posted, you have given the answer in form or another.. Hats off to you mate ![]() |
Not really Ash, I'm just a sad sod with nothing better to do with my time than play about with the car, and read workshop manuals, most of it can be found with a couple of click of a mouse |
Three different answers depending on the age of the RRS in question. Which sums up Land Rover ownership to a tee! |
