Home > General > Ghost immobiliser anyone ?.
dazza2802
England 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi all
Being one of the big boys with their toys .. (and girls), I have just bought a 2011 RRS tdv6 3.0 hse (L320) and having seen the most stolen to order cars at the moment are RRS and BMW something or other, I thought that I had better get some protection, although it’s an oldy, it’s my oldy. I am currently looking at the Ghost immobiliser 2. At £500 ish, it isn’t cheap, but looks like it’s the doggies danglers. I am looking for anyone who has found it to be problem. Ie not accepting the code or stopping the car for no reason. The last immobiliser I had was probably 20 years ago and they were notorious for causing problems.
Any advice or reviews would be greatly appreciated and if and when I get it I shall report on everything from installation to day to day usage of it
Thanks very much guys and gals
Post #611212 Tue Mar 09 2021 11:28am
Ash3
Autowatch Gost 2 fitted to MY2016 L494.
Had a slight issue after about a year, wouldn't let car start even though I put the correct code in...supying dealer sorted it free of charge....he came round and got to the wiring and got started to take to his workshop...
Turns out software had become corrupted by too many incorrect / rapid code sequence entries....which was true...some times I would put code in very quickly but car would not start so would enter it again...
Apparently you should enter code in a steady manner entering each "nmr" in about 1s intervals to allow ghost to register the entties to disarm itself. On the upside seems it failed active....so proved it works
Several monts on...No issues...would recommend and Disk Lok gor sterring wheel...visible deterrent Thumbs Up
Post #611213 Tue Mar 09 2021 12:00pm
dazza2802
Thanks Ash. That makes sense really. Sounds like a professional outfit
Post #611215 Tue Mar 09 2021 12:12pm
Eagle77
Ash3 - where did you get yours fitted?
Post #611218 Tue Mar 09 2021 12:52pm
Ash3
A local fitter in London... Leyton E10 area...if you are around this area or not far I can getvthe address for you.
Yes very nice fella and professional
Post #611221 Tue Mar 09 2021 1:31pm
Autobiography1969
Autowatch Ghost 2 fitted to MY 2012 L320
used https://ghostinstallations.co.uk/
For mine, came darn sarf and fitted it, showed me
how it all works, and made sure I was happy before they
left for home, even called a couple of weeks later to make sure
I was still happy, never had any issues, and it does exactly what
it says on the tin..
Highly recommend them..
also if you want a dash cam they supply and fit them too.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #611246 Tue Mar 09 2021 6:40pm
dazza2802
I have a nasty habit of overthinking things.. and on that note. Do the fitters tell you were they have “hidden” the immobiliser box. As I understand it, the box is about half credit card size and can literally be anywhere in the electrical system. Reason I’m thinking of this, is, what if the company goes bust and a problem occurs with it. If I take it to my usual mechanic, would he be able to sort problemo out..
See, I said I overthink things lol
Post #611275 Wed Mar 10 2021 9:22am
Kitchenfitter
Hi, I am also getting a ghost fitted soon as just got my 62 reg Autobiography as well as a tracker
I currently have a ghost and tracker fitted to my Mustang
Ghost costs £400 fitted and tracker £200 fitted + £12.50 per month
Well worth the peace of mind
Post #611312 Wed Mar 10 2021 6:54pm
Kitchenfitter
Post #611313 Wed Mar 10 2021 6:54pm
dazza2802
Yea, I’ve done loads more research and I’m definitely getting it fitted with the tracker that’s on offer at minute. Thanks to all that’s put their views forward
Post #611317 Wed Mar 10 2021 7:54pm
Ash3
They should do as it is your car. They should also show you how to change the pin code to disarm it. My fitter told me all that.
Post #611330 Wed Mar 10 2021 11:11pm
dazza2802
Thanks Ash
Post #611344 Thu Mar 11 2021 1:34pm
MrM
To answer the question about location. I know the rough area where it was installed, but I didn’t particularly want to know where it was being installed to be honest. I imagine if I needed to I’d be able to find it.
Post #611352 Thu Mar 11 2021 2:22pm
Kitchenfitter
The chap I use is based in Coventry
Post #611368 Thu Mar 11 2021 9:36pm
Kitchenfitter
Having the ghost fitted on my RRS today as well as a tracker
Post #611970 Sat Mar 27 2021 10:29am
