Home > General > Help handbrake jammed! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
If you are going to cut any cable, cut the drivers side on. Thats the easier one to replace
Sat Mar 06 2021 1:53pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
When DM says very (VERY) tight to release he is understating it. It took me and my son with a strong length of wood to release mine. Me on one front seat, my lad other on the seat, a length of steel rod with a hook at the end round the release cable and then the other end round 2 foot length of 1" square timber , both lifting. It's not just the force required, its also the tight access making it difficult to do on your own. Worth trying rather than cutting cables
Sat Mar 06 2021 2:13pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 212 |
Have a look on you tube, I had the same on my TDV8 all I needed was a cable tie to release it the surround near the gearshift is easy to remove & the release for the handbrake is clearly visible. |
Sat Mar 06 2021 2:47pm |
Gazc2 Member Since: 06 Mar 2021 Location: Perth Posts: 6 |
Gents very much appreciate the swift response I will try the release cable again tomorrow I maybe was slightly wary of putting too much on it
Sat Mar 06 2021 2:52pm |
No, if you resort to cutting, just one cable will suffice
Sat Mar 06 2021 9:53pm |
cheers Mikey spot on |
Sat Mar 06 2021 10:44pm |
So just to update I was succesfull with the release cablešstuck a couple of karabiner on it and gave it a hefty tug and bobs your uncle a bit wary yesterday when you see the small loop I was worried about bursting it, thanks again for the help |
Sun Mar 07 2021 3:10pm |
Its much stronger than it looks |
Sun Mar 07 2021 4:19pm |
Sun Mar 07 2021 9:19pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Thatās is a simple, and fantastic idea! |
Mon Mar 08 2021 10:14am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I think some people use the handle of the Land Rover supplied 'widow maker' jack to pull the release which seems to do the job also. Kev
Mon Mar 08 2021 8:55pm |
Desperado Member Since: 03 Nov 2020 Location: NSW Posts: 1 |
Yep, that's what the manual says. |
Sat May 08 2021 6:56am |
