![]() | Home > Technical > Anti roll bar bushes - rubber or Poly? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Rubber tends to dry out and creak. We fit polys, and never had one come back |
Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
Cheers bud |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Which ones do you use out of interest? I have them on my front ARBs and I've not heard a knock in 40k+ miles. Will likely replace any other with poly as they come to need replacement |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
SuperPros going in mine front and rear on Wednesday |
I've seen online that there are two types,
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 ![]() ![]() ![]() |
If you pop the bonnet and check to see if you have an extra fluid reservoir with a yellow cap (like your power steering) on the front left hand side of the engine bay, if you have this then you have hydraulic ARBβs then you have ACE/Dynamic Response
Thanks Lee!
