Home > Technical > Anti roll bar bushes - rubber or Poly?
Sparkey
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Firenze Red
I'm going to get the anti roll bar bushes and drop links done on my 2012 RRS.
Whats the thoughts on fitting O.E spec rubber or polyurethane bushes?
Post #609571 Fri Feb 05 2021 9:14am
Disco_Mikey
Rubber tends to dry out and creak. We fit polys, and never had one come back Thumbs Up
Post #609577 Fri Feb 05 2021 12:12pm
Sparkey
Cheers bud Thumbs Up
Post #609583 Fri Feb 05 2021 4:55pm
Pufftmw
Which ones do you use out of interest?
I have them on my front ARBs and I've not heard a knock in 40k+ miles. Will likely replace any other with poly as they come to need replacement
Post #609587 Fri Feb 05 2021 6:09pm
Buckster
SuperPros going in mine front and rear on Wednesday Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #609605 Sat Feb 06 2021 10:52am
Sparkey
I've seen online that there are two types,
One for a vehicle with ACE, and one without.
Being new to this vehicle, is there any way to tell which I have, so I order the correct ones?
Thanks for any help.
Post #609613 Sat Feb 06 2021 12:56pm
Leechicken74
If you pop the bonnet and check to see if you have an extra fluid reservoir with a yellow cap (like your power steering) on the front left hand side of the engine bay, if you have this then you have hydraulic ARB’s then you have ACE/Dynamic Response
 Lee
β€”β€”β€”β€”β€”-
3.6 TDV8 2010 (facelift) HSE Stornaway Grey
3.0 TD6 2018 Discovery HSE Luxury Indus Silver Dynamic Packs 1 & 2 - Sold due to COVID budget cuts at home 😒
Mini Countryman 2.0 Cooper SD All4 - White, black wheels, black decals - Great little car and so much fun!
Post #609614 Sat Feb 06 2021 2:03pm
Sparkey
Thanks Lee!
Excellent response Thumbs Up
Post #609623 Sat Feb 06 2021 4:35pm
