![]() | Home > Faults & Fixes > RRS 2011: suspension fault stop safely stop engine - leaking |
jig Member Since: 14 Jan 2018 Location: London Posts: 40 ![]() ![]() |
help fellow rrs owners! |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Not completely up to speed with your particular model but the suspension compressor is related to the air suspension in each wheel arch. The dynamic suspension is the front and rear roll bars which are oil and is driven by a pump,, which I'm sure will be belt driven off the engine. Quite often the problem is the pipework that runs front to back as it is open to the elements and therefore suffers from corrosion but you say you have an unhealthy noise when you start the engine,,, which I guess is the pump. If this is so I wouldn't think topping the oil up would make it safe enough to drive as the pump sounds fubarred. Depending on how good you are with spanners will depend how easy the job is I suppose,, not having done this myself I can't really comment any further I'm afraid but I'm sure someone else will comment and keep you right. 2010 RRS, TDV8
thanks for the information, that is useful, the model is ranger rover sport 2011 L320, lets see what fello forumites come up with! |
Also the fluid has been seen dripping from the drivers side wheel arch... |
Drivers side wheel arch leak will be the dynamic response fluid. There are four pipes there which the flow and return pipes for both anti roll bars. It is a DIY-able. Just do a search on here...
Hi Guys, thanks for all the advice. I have managed to find the leak it is from the lower pipe out of the 4 and its seem like its is leaking from the bracket onwards, see pics.
thanks knwatkins, do you know if I can just fix the one pipe and does it come of at the joints or does the whole thing need to be replaced? thanks |
bump |
