![]() | Home > Maintenance & Modifications > L494 Seat strip down and heated seat diagnoses |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Chances are it’s the temp sensor or an element.
GJOB Member Since: 18 Jan 2021 Location: Northants Posts: 5 ![]() ![]() ![]() |
Hi Andy,
each seat has its own temperature sensor to regulate the heat |
I see, so you'd expect a fault code to be present then? I did ask the garage if they could check the codes and they advised there wouldn't be one for the seats.
It maybe worth finding out if the sensor is built into the heating pad.
will do, thanks. |
Found a new garage, quoted less than £200 for parts and labour inc vat and they'll test it first. Am happy with that. |
DickieDavis Member Since: 05 Jan 2022 Location: Berkshire Posts: 1 ![]() ![]() |
Can I ask the name of the garage please |
