Home > Maintenance & Modifications > L494 Seat strip down and heated seat diagnoses
GJOB
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hi All,
I'm a newbie to this forum, a long time Range Rover owner spanning P38, L322 and now a 2014 L494.
The drivers side heated seat stopped working and it coincided with the battery needing replacing so I thought it would be rectified when I had it replaced but alas, no.
Apparently there's little to no information to be obtained from fault codes so I'm presuming that the only way to get a proper diagnosis is to strip the seat down and check the circuit.
A coupe of questions (I did a search first to no avail):
1. How easy is it to strip the seat down? I have the WSM but I'd like to hear from someone who's do it themselves
2. Are there any other ways of diagnosing the fault before I buy the heated pads and strip the seat only to potentially discover they're not faulty :/
I contacted a local garage who quoted £600 to fix it which sounds a bit extreme unless I'm missing something
Thanks in advance
Simon
Post #608884 Wed Jan 20 2021 7:14pm
Chances are it’s the temp sensor or an element.
If you have an iid you could read the temperate to see if it’s correct / valid
Post #608885 Wed Jan 20 2021 7:36pm
GJOB
Hi Andy,
I don't have an IID unfortunately. The passenger and rear seats are all find so I've ruled out fuses and sensors but perhaps I shouldn't have been so quick to come to that conclusion?
Post #608925 Thu Jan 21 2021 1:21pm
each seat has its own temperature sensor to regulate the heat
Post #608929 Thu Jan 21 2021 1:49pm
GJOB
I see, so you'd expect a fault code to be present then? I did ask the garage if they could check the codes and they advised there wouldn't be one for the seats.
I'll try a different garage!
Post #608933 Thu Jan 21 2021 2:10pm
It maybe worth finding out if the sensor is built into the heating pad.
In which case your back to changing one item
Post #608936 Thu Jan 21 2021 2:24pm
GJOB
will do, thanks.
Post #608937 Thu Jan 21 2021 2:38pm
GJOB
Found a new garage, quoted less than £200 for parts and labour inc vat and they'll test it first. Am happy with that.
Post #608942 Thu Jan 21 2021 3:19pm
DickieDavis
Can I ask the name of the garage please
Post #620576 Wed Jan 05 2022 11:14am
