![]() | Home > General > Probably a stupid question... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
Nope |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I think I've read somewhere here that whilst this is a bit of a surprise to those not in the know, it tends to happen more if the FBH hasn't been in use for a while. So you see it most when mild weather turns to cold and it fires up for the first time in a while. If its regularly cold each morning and the car is used regularly, then it doesn't always produce lots of vapour. Speaking from experience I use mine quite a bit (I have a remote fitted) and don't notice any vapour. Even in summer I have been know to start it half an hour before I start the car. My theory (totally unproven) is that anything that warms up the engine a bit before starting can only be to the good. So, if you feel its an issue get a remote fitted so that you can fire up the FBH where its parked (driveway?) before you need to drive off and thus avoid the problem of the good Samaritan stopping you again. ![]() 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
Mine did smoke quite a bit the first few times it fired up but it’s smoke free now. Steve
