Home > General > Ultrasonic cleaning of plastic manifolds on TDV8?
Slowpoke Disco
Australia 2008 Range Rover Sport TDV8 S Stornoway Grey
Hi everyone,
a newbie here from Australia.
Has anyone successfully, or otherwise, tried ultrasonically cleaning of plastic manifolds or even things like oil separator parts for their TDV8? My 3.6 has been diagnosed with excessive carbon buildup inlet manifold and intake pipes leading to oil coming out of the dipstick. I've only seen one other person on the forums having this exact issue and they never said what the cause was..
I'm thinking about cleaning the inlet manifolds, air intake pipes, crankcase ventilation oil return drain pipes etc but before I do, and possible stuff them up completely I thought I'd ask. I've seen cleaning of injectors on the forum but not manifolds and given their cost new here in Australia I'm keen to look at options.
Any brilliant ideas?
Post #608142 Mon Jan 04 2021 11:56am
IronDuke50
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Firenze Red
Best of luck. Ive left this site,
Post #608151 Mon Jan 04 2021 4:32pm
Slowpoke Disco
Yep that looks even more tempting now I've seen what they did with that manifold in particular. I'm going to a cylinder head rebuilder tomorrow for my boat motor and I know they use their ultrasonic cleaner for their headwork so I'll see if I can organise them to try one of my manifolds. There's no end to what could potentially be cleaned.
Assuming they say yes then I guess the next thing I need to plan is when I could do the work, pulling all the manifolds etc and then organising new gaskets etc so my car isn't off the road for weeks waiting for parts.
I'm still struggling to completely understand why the blocked manifolds would cause too much crankcase pressure but I'll keep reading about it. I'll let you know once I've spoken to the head guys.
Matt
Post #608167 Tue Jan 05 2021 2:08am
If you're taking the manifolds off and cleaning it all out, may as well replace the EGRs and the crankcase ventilation oil separator. They'll have to come off anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #608171 Tue Jan 05 2021 9:48am
Slowpoke Disco
Yep, looking forward to seeing what's underneath the manifold cover. Hopefully nothing major broken but I couldn't be that lucky.
Post #608176 Tue Jan 05 2021 12:21pm
Slowpoke Disco
Hi,
just a follow on up on this in case it helps someone else.
The issue I was having with the dipstick pushing out oil when driving my 3.6 TDV8. It turns out I had a hairline internal crack somewhere in the inlet manifolds/rocker cover. I was able to do the right hand cover myself at home but couldn't do the left without removing the a/c gas so I paid for that to be done by someone else.
I was going to be charged for pressure testing the old manifolds so I just replaced both. I initially only intended to replace the right hand one if it was broken but I was told (after I'd spent 2 cold nights in the shed) that if you replace one, and even if it's broken, then the other 'good' manifold will likely then also fail because there's now going to be more airflow through the one that's okay. It would have been nice to know that from the start.
I'd seen write ups where people were told to remove the PCV system but after studying that I couldn't see how there'd ever be enough positive airflow into the sump from that. It was only happening when the engine was on boost and then the crack expanded enough to allow excess air into the crankcase and then the dipstick was the only way out.
Either way, replacing the manifolds worked and it's been great since. Dipstick hasn't moved and no oil spray anywhere like before. Something for someone who gets this issue in future.
Post #617080 Wed Sep 08 2021 3:39pm
Thanks for the follow up Slowpoke. Thumbs Up
That's useful data for the collective and it's also nice to see a recent member following up their issue.
Here's to many happy miles in the future. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #617090 Wed Sep 08 2021 9:53pm
