![]() | Home > Technical > TPMS Error Message |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5109 ![]() ![]() ![]() |
Have opposite fault to you on my RRS1, mine won't even locate the spare, although will if fitted to car. Bit of mucking around but could fit spare to car and see if system locates it o.k. with no message, if still get the message from that wheel position on the car suspect it may be a faulty sensor or sensor battery, although thought I did read somewhere it flashes a different message of some sort if sensor fault. Nothing much to reset in the CCF files, there doesn't seem to be any fault codes available for the spare wheel if it has a fault either, although there is for the other wheel positions, could always turn the spare wheel setting off for time being if you wanted too, but obviously doesn't solve the issue. Tried new sensor and receiver on mine, they don't seem to mention a separate aerial for the spare wheel though so assume there isn't one and the other are all o.k. as the rest of the system works. Find's wheel on car o.k. but not when fitted in spare wheel well.
rickshaw Member Since: 03 Jul 2007 Location: West Yorkshire Posts: 199 ![]() ![]() ![]() |
Thanks Col.
Yeah, niggles me a bit that I can't get mine to work, this is my temp mod to check mine, at least it saves me rolling around on the floor, don't have a problem getting down there it's the getting up I have the problem with. |
