Home > Technical > TPMS Error Message
rickshaw
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
TPMS Error Message
I keep getting a warning message saying that the pressure in my Spare Tyre is low. Have checked the settings (currently set for light load) and the actual pressure in the spare and all appears to be correct.
Is it possible to 'reset' TPMS to clear the message or is it likely to be a fault of some sort?
Any thoughts welcome!
Post #607480 Mon Dec 14 2020 5:43pm
Have opposite fault to you on my RRS1, mine won't even locate the spare, although will if fitted to car. Bit of mucking around but could fit spare to car and see if system locates it o.k. with no message, if still get the message from that wheel position on the car suspect it may be a faulty sensor or sensor battery, although thought I did read somewhere it flashes a different message of some sort if sensor fault. Nothing much to reset in the CCF files, there doesn't seem to be any fault codes available for the spare wheel if it has a fault either, although there is for the other wheel positions, could always turn the spare wheel setting off for time being if you wanted too, but obviously doesn't solve the issue. Tried new sensor and receiver on mine, they don't seem to mention a separate aerial for the spare wheel though so assume there isn't one and the other are all o.k. as the rest of the system works. Find's wheel on car o.k. but not when fitted in spare wheel well.
Post #607488 Mon Dec 14 2020 9:08pm
rickshaw
Thanks Col.
Good idea! I'll give it a try when I get chance. Not really a big issue but a slight annoyance..
Richard
Post #607499 Tue Dec 15 2020 9:30am
Yeah, niggles me a bit that I can't get mine to work, this is my temp mod to check mine, at least it saves me rolling around on the floor, don't have a problem getting down there it's the getting up I have the problem with. Laughing
Post #607530 Tue Dec 15 2020 11:28pm
