Home > In Car Electronics > Solar charging
Craigb86
Solar charging
I've currently got an obd aa charger solar which I've tested and it does give current however it triggers the radio display to be on so I believe it's going to lose rather then gain.
The fix is to wire to the battery directly however my question is can I do a panel to the battery and still drive as my aa one you can't drive with. I wanted a solution that can stay in place and not connect and disconnect etc
Post #606429 Sun Nov 08 2020 11:29pm
1richard1
Put a switch in the cable and turn off before starting up.
Post #606433 Mon Nov 09 2020 6:28am
Craigb86
So you couldn't drive with a solar charger running?
Post #606437 Mon Nov 09 2020 9:04am
1richard1
Not if its turned off.
Post #606441 Mon Nov 09 2020 10:00am
why can't you drive with your AA one connected ?
Post #606446 Mon Nov 09 2020 1:06pm
