Home > Maintenance & Modifications > Remote FBH Heater switch on £60 (early models) NOW £80
A few Disco owners have been fitting these
They offer a value for money way to warm your diesel car up in the morning.
https://www.ebay.co.uk/itm/124117320536
W-BUS Mods: FaceLift/D4 Sat Nav Display and reverse camera. BT. Remote FBH. Parking light switch position. Rear reading light activated by doors.
Post #606038 Thu Oct 29 2020 1:29pm
Keith1961
Northern Ireland 2011 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Hi Andy,
Is there much involved in fitting it?
Post #606383 Sun Nov 08 2020 6:00am
IT SAYS UPTO 2010
It’s just 3 wires.
2 for power
1 to the heater. As yours isn’t a 2005 year, you will need to buy a terminal pin from the RRS shop
https://www.disco3.co.uk/shop/fbh-connecto...o-p41.html
For your facelift model I would have thought you would go a more landrover way.
Eg timed climate or LR remote
Post #606390 Sun Nov 08 2020 11:54am
Stevepd
Isn’t this what Kev is selling from his L320? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #606406 Sun Nov 08 2020 4:25pm
Keith1961
I have the timed climate which works well, just thought adding a remote I could work from the house would be useful.
Post #606411 Sun Nov 08 2020 5:49pm
I don’t think it’s compatible with your year.
I would stick with LR stuff on that age.
There is a remote receiver you can fit in the rear.
Post #606412 Sun Nov 08 2020 6:18pm
Keith1961
Thanks Andy, is the remote receiver a dealer accessory only?
Post #606467 Mon Nov 09 2020 8:50pm
J4XHY
United Kingdom 2007 Range Rover Sport TDV6 HST Java Black
Thanks for links Andy. I've got a 2007 RRS 2.7. I take it I need to check if I have a cable on pin 2 on the heater. If not I need to buy the repair wire and add that?
+12v and - 12v. Did you splice the heater power or straight to battery?
Thanks
Post #609966 Sun Feb 14 2021 10:25am
I expect you need to buy a terminal and wire on 2007
Most people connect to earth stud and the thick battery +
Post #609967 Sun Feb 14 2021 10:37am
A disco install
11891952 wrote:
Mine is now fitted and working. As already said, all simple enough, only three wires, though I did leave the fourth accessible just in case.
Unit in battery box
Power wires bottom right
Post #609968 Sun Feb 14 2021 10:45am
