![]() | Home > Maintenance & Modifications > Remote FBH Heater switch on £60 (early models) NOW £80 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
A few Disco owners have been fitting these
Keith1961 Member Since: 09 Mar 2020 Location: Belfast Posts: 23 ![]() ![]() ![]() |
Hi Andy,
IT SAYS UPTO 2010
Isn’t this what Kev is selling from his L320? 2006 2.7 TDV6 HSE in Cairns Blue. |
I have the timed climate which works well, just thought adding a remote I could work from the house would be useful. |
Thanks Andy, is the remote receiver a dealer accessory only? |
J4XHY Member Since: 14 Feb 2021 Location: South Wales Posts: 20 ![]() ![]() ![]() |
Thanks for links Andy. I've got a 2007 RRS 2.7. I take it I need to check if I have a cable on pin 2 on the heater. If not I need to buy the repair wire and add that?
I expect you need to buy a terminal and wire on 2007
A disco install
Unit in battery box Power wires bottom right |
