![]() | Home > General > Now the suspension has started to play up |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Sounds all normal to be - the raising slowly message is not a fault message but just an advisory - most likely the tank was low of air but was not low enough to trigger the compressor when you shut down - particularly when you lowered to access height so not demand in that.
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
Thanks for the reply
Managed to get under the car this morning, It seems as the compressor wasn't upgraded as thought when Dad originally got the car. Pictures attached are my compressor, it's an Hitatchi but i can't find any markings or tags to say if it's a genuine one or not. I am going to look for a replacement and hopefully get a rebuild kit for this one, still looking quite clean though. The bit that's really got to me is that i replaced the front bottom arms 2 months ago, and while i was under the car i saw that the rubber boot on the one bottom ball joint was split open. Another job to do.
Just freshen up what you have - my Hitachi is 13 years old and still runs fine - only one freshen up.
You can buy Dunlop compressors for £195+VAT here: https://www.lrparts.net/lr023964-air-suspe...relay.html
Dunlop compressors like the other knock-offs really do not have a good reputation as highlighted on this forum and the Disco 3 forum. 07MY RRS TDV6
I had one on my L320 for two years and it never missed a beat. I've heard of hardly any issues with them.
Is there a rebuild kit anyone would recommend?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5132 ![]() ![]() ![]() |
A genuine L/R will have something like this on the end of it, not sure what a genuine Hitachi aftermarket replacement would have on it though. If it's lasted 10 years I would suspect it is either L/R or Hitachi genuine unit, if it had been a Chinese copy be lucky if it had lasted 10 days.
https://x8r.co.uk/land-rover-discovery-3-4...hi-end-cap As far as the genuine item goes - like all things quizz thr seller on this. If it says Hitachi Type it just means it is a copy. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Looking around at all the chinesium compressors, it seems that only the genuine compressors have the red and blue fittings. As mine has these i am betting it is genuine. I am going to order the rebuild kit. The one in the link provided has an aluminium billeted end cap, so i am going to go for that as i have read that the original ones crack over time. On the bright side the car hasn't played up today. 55 plate
Yes definitely go the aluminium cap - you will safe on problems later. 07MY RRS TDV6
Attempted the rebuild today, started at 9.30am and at 3pm still hadn't got the compressor off. The bottom bolt, the awkward one under the dryer is rusted in and rounded off. It was already rounded when i started. I have quite a range of sockets for different scenarios, but nothing i tried would grip. The only thing i hadn't got was the irwin bolt removers, so off i went to get some. Completely useless in this situation, they just won't grip onto the bolt head. I have tried almost everything. The only 2 options left are try to get a reciprocating saw between the aluminium bracket and chassis, hopefully. Or get a new bracket and cut the bottom off the one that's fitted to the car. On the plus side the hard to reach top bolt is missing, and the compressor is a genuine land rover one as i found the markings on it. 55 plate
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Don't know how much room you have will not a gripper type socket get it off.
