![]() | Home > General > Loose steering? |
Dunc101 Member Since: 16 Nov 2017 Location: Bedfordshire Posts: 33 ![]() ![]() ![]() |
Hi all - apologies if this has already been covered: I’d appreciate any links to relevant threads if it has.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
I'd look at lower wishbone arm bushes next. If it is them then the perceived wisdom here is to change the whole arm rather than just the bushes. Robin
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I would also check the front anti roll bar bushes. I had similar symptoms to you and also suspected lower wishbones but on inspection there was no obvious play but as soon as new ARB bushes were fitted the clunk disappeared and everything felt nice and tight again especially over bumpy roads. 2010 TDV8 - current - my first RRS, loving it so far......
That’s all great advice, thanks all. The car is booked in in a couple of weeks time so I’ll get these and any other parts that others may recommend in the interim, checked. |
