Home > General > Vehicle lean when cornering |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
The usual solution is to read the codes first to see whats causing the warning to come on... |
Mon Aug 31 2020 6:32am |
Also, does it re-appear if you switch off and leave it for half an hour then restart? Robin
Mon Aug 31 2020 8:56am |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
The error was on all day yesterday even though I left the car for a few hours between starting.
Mon Aug 31 2020 1:55pm |
The reason I ask is that I occasionally get an error message regarding suspension or special programs. It doesn't seem to affect handling for day to day road trips. And if I leave it the error does not re-appear for a while. The best theory I have had is that you shouldn't turn on the ignition and then try to start it. Count to 5 then start. This seems to reduce the incidence of the error.
Mon Aug 31 2020 2:01pm |
Got the codes read today and there is no error codes stored. I didn't know its possible to have an error appear but have no codes stored.
Mon Aug 31 2020 5:55pm |
Yes. That’s it. My theory (totally unproven) is that it doesn’t like being started until it’s had a chance to get all the electrics fires up. So ignition on, wait till the display shows it’s done it’s self checking thing (about 5 seconds) Then you can start. I’ll be interested to know if it improves it for you. Robin
Mon Aug 31 2020 10:18pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
does it have ACE? if so is the fluid running low |
Fri Sep 04 2020 4:48pm |
It has ACE. The fluid level is slighly above maximum. It hasn't happened since |
Fri Sep 04 2020 7:34pm |
This error appeared again today. Still no error codes stored and ACE fluid is at the maximum line.
Thu Sep 24 2020 6:08pm |
Need the fault codes read first.. |
Thu Sep 24 2020 8:30pm |
As above, I've had the fault codes read and there isn't any stored |
Thu Sep 24 2020 9:48pm |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
What diag system did they use?
Thu Sep 24 2020 11:08pm |
Took your advice and tried with a different reader today and got the following codes:
Fri Sep 25 2020 12:17pm |
