Home > Technical > alternator killing sockets |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4322 |
ARC pump needs removed. Can't access both lower bolts with it in place... |
Sat Aug 29 2020 9:33pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Am confused. I've removed both lower bolts, they were a doddle. What's screwing me was upper bolt. Nothings blocking the lower bolts for me
Sun Aug 30 2020 7:30am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
Oh you got a petrol
Sun Aug 30 2020 8:27am |
ah ive been using socket and 3/8. the video was just my last attempt with 13mm rachet spanner because the bolt has broken 3 13mm sockets already
Sun Aug 30 2020 9:24am |
I always just assume its a diesel we are talking about |
Sun Aug 30 2020 9:33am |
ahh fair enough explains why my ace pump isnt in the way my issue is i cant get the leverage to crack the sucker open, maybe am just that weak |
Sun Aug 30 2020 9:41am |
Longer breaker bar. 1/2ā to 3/8 adaptor.
Sun Aug 30 2020 9:58am |
I've got some impact 13mm that'll hopefully take the strain. I've got a pipe that I use as a breaker bar so we'll see |
Sun Aug 30 2020 12:19pm |
Smashed it, draper impact socket did the trick. I also think I made it harder for myself by removing the two bottom bolts first because then all the weight was on the top bolt. |
Sun Aug 30 2020 7:24pm |
