Home > Technical > alternator killing sockets
mgrover
so far the upper alternator bolt has destroyed 3 13mm sockets Razz Am attempting this from below and I do have ACE installed. Do I need to remove the ACE pump blocking the way or is using a few thin extensions and maybe a swivel socket will do?
Or shall I just remove the fan and attempt to get an impact in there? The thing is crazy tight and 1/2 inch bits won't fit either, although 1/2 inch bit fits the other two bolts. they were dry as meaning no grease was applied.
any other tips i could attempt? literally the only thing left holding the alternator on, new one which is denso arrives on monday. 270quid from CP4L. Which is a steal imo
Post #603906 Sat Aug 29 2020 6:11pm
Disco_Mikey
ARC pump needs removed. Can't access both lower bolts with it in place...
Post #603914 Sat Aug 29 2020 10:33pm
mgrover
Am confused. I've removed both lower bolts, they were a doddle. What's screwing me was upper bolt. Nothings blocking the lower bolts for me Shocked
https://photos.app.goo.gl/wAA5oMiAYSYVXpt18
Also if I plug the battery back in and remove the alternator fuse/relay will that sever the link between the alternator and battery? There were a lot of sparks when the aa man tried to charged the battery for drive home
Post #603921 Sun Aug 30 2020 8:30am
Oh you got a petrol
The main thick red cable connects to the alternator and starter.
Video shows a ratchet spanner.
Have u tried a 3/8th socket and ratchet
Eg
https://rover.ebay.com/rover/0/0/0?mpre=ht...3019197654
https://rover.ebay.com/rover/0/0/0?mpre=ht...0650916513
I’m sure Halfords sell 3/8th sets
Post #603922 Sun Aug 30 2020 9:27am
mgrover
ah ive been using socket and 3/8. the video was just my last attempt with 13mm rachet spanner because the bolt has broken 3 13mm sockets already
my main issue is its torqued so high i cant get the leverage to break it loose
Post #603926 Sun Aug 30 2020 10:24am
Disco_Mikey
I always just assume its a diesel we are talking about Embarassed Laughing
Post #603928 Sun Aug 30 2020 10:33am
mgrover
ahh fair enough explains why my ace pump isnt in the way Razz my issue is i cant get the leverage to crack the sucker open, maybe am just that weak Razz
Post #603929 Sun Aug 30 2020 10:41am
Longer breaker bar. 1/2ā€ to 3/8 adaptor.
Or just a longer ratchet
I got the snap on version of this
https://rover.ebay.com/rover/0/0/0?mpre=ht...3799537284
Handy.
But 1/2ā€ breaker bar is king
Post #603930 Sun Aug 30 2020 10:58am
mgrover
I've got some impact 13mm that'll hopefully take the strain. I've got a pipe that I use as a breaker bar so we'll see
Post #603932 Sun Aug 30 2020 1:19pm
mgrover
Smashed it, draper impact socket did the trick. I also think I made it harder for myself by removing the two bottom bolts first because then all the weight was on the top bolt.
Post #603939 Sun Aug 30 2020 8:24pm
