Home > General > front screen causes revs to drop slightly?
mgrover
exactly what it sounds like, if i put on the front heated screen, my revs drop for a second then car idles fine again. is this based off some pulley i didnt know about or has some electrics somewhere gone wrong?
Post #603246 Thu Aug 13 2020 2:50pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
The front screen heater draws a very big electrical load, the fall in RPM is because the alternator suddenly has to provide this and causes a significant drag on the engine that takes a little time to respond.
It’s perfectly normal
Post #603251 Thu Aug 13 2020 4:42pm
mgrover
fair enough nothings bust then Razz ive gotta get the rear spoiler off and see why the rear one isnt working next.
Post #603253 Thu Aug 13 2020 5:58pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Re: front screen causes revs to drop slightly?
Begs the question as to why you're putting on the screen heating in this weather? Rolling with laughter 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #603263 Thu Aug 13 2020 10:54pm
mgrover
I was just messing around curious :p
Post #603271 Fri Aug 14 2020 7:34am
The heated windscreen draws 27.5A each side, so 55A in total. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #603274 Fri Aug 14 2020 7:56am
mgrover
hmm from what ive noticed in the past the driver side seems not to work as well as the passenger so i wonder if its a seperate fuse which is knackered?
Post #603278 Fri Aug 14 2020 10:33am
It’s probably wishful thinking.
To find out locate in windscreen connectors either side.
And then measure the voltage each side with it on.
Connector tabs are inside under A pillar
Compare left and right.
It’s probably a knackered screen though
Post #603279 Fri Aug 14 2020 11:19am
geoffsnook
Yeah my screen was the same only half worked well Thumbs Up
Post #603282 Fri Aug 14 2020 12:12pm
Don't forget that the side airbag pack lives on the A-pillar behind the trim so just be a bit careful when accessing it all. Be really annoying to set that off! Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #603286 Fri Aug 14 2020 2:40pm
idi
I like how you just say that so casually. Like its common knowledge to know these things.
Post #603291 Fri Aug 14 2020 4:02pm
idi - info available in the workshop manual that is freely available to download. Took me 2 minutes to open the manual and check the wiring diagram. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #603305 Fri Aug 14 2020 11:00pm
mgrover
Do you guys ever think might be handy to just have a massive faq post :p I feel bad spamming a million and one things everyday thats gone wrong :p today's is hesitation to drop down gears when putting foot down but not using kickdown
Post #603309 Sat Aug 15 2020 5:05am
I think that would be a very long index of questions with no answers, taking into account not everybody can be bothered posting a reply when they get the issue fixed to maybe help others with the same or similar issue. I think it would be quicker to keep asking you questions. Laughing
Post #603310 Sat Aug 15 2020 5:15am
Tim in Scotland
There is a “Search” function on the tool bar below the forum banner so no need for an FAQ section 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #603315 Sat Aug 15 2020 7:56am
