![]() | Home > General > front screen causes revs to drop slightly? |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227
The front screen heater draws a very big electrical load, the fall in RPM is because the alternator suddenly has to provide this and causes a significant drag on the engine that takes a little time to respond.
| mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393
fair enough nothings bust then |
| Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100
Begs the question as to why you're putting on the screen heating in this weather? 2005 Cayenne S - handling defied physics and what a sound, so sod the mpg! 1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim Lots of other non 4X4's in between times......... |
I was just messing around curious :p |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The heated windscreen draws 27.5A each side, so 55A in total. |
hmm from what ive noticed in the past the driver side seems not to work as well as the passenger so i wonder if its a seperate fuse which is knackered? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143
It’s probably wishful thinking.
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Yeah my screen was the same only half worked well |
Don't forget that the side airbag pack lives on the A-pillar behind the trim so just be a bit careful when accessing it all. Be really annoying to set that off! |
| idi Member Since: 19 Nov 2019 Location: England Posts: 134
I like how you just say that so casually. Like its common knowledge to know these things. |
idi - info available in the workshop manual that is freely available to download. Took me 2 minutes to open the manual and check the wiring diagram. |
Do you guys ever think might be handy to just have a massive faq post :p I feel bad spamming a million and one things everyday thats gone wrong :p today's is hesitation to drop down gears when putting foot down but not using kickdown |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
I think that would be a very long index of questions with no answers, taking into account not everybody can be bothered posting a reply when they get the issue fixed to maybe help others with the same or similar issue. I think it would be quicker to keep asking you questions. |
There is a “Search” function on the tool bar below the forum banner so no need for an FAQ section 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| All times are GMT |
