![]() | Home > Maintenance & Modifications > L494 cigar lighter |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
it just 2 spade connectors isn't it ? or they could be used
arh maybe they have a fancy 3 pin connector these days |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Unfortunately not, it's a 3 spade connector, plus the illumination feed for the "light ring".
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5116 ![]() ![]() ![]() |
A lot of L/R connector/plugs are TE Amp you may find what you are after on their site, but there is a awful lot to look through. |
Thanks Col,
Having 3 pins is the light already counted for ? |
I think the 3rd tab is the earth to the light. There looks to be a connector of sorts for the illumination feed on the outside. Should be easy enough to make something that works for that if I can't find the connector. 2006 RRS S/C CONSTANTLY under modification...
