![]() | Home > General > Paint peeling on side sills |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Is it just the paint finish or is it right down to the plastic underneath?, if so initially I would say the plastic wasn't prepped and primed properly prior to top coat. Any possibility it's had a replacement sill trim fitted at some point.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I am sure this isn't the case (but just in case) I do worry about jet washers. They are very powerful. I remember reading somewhere that you shouldn't use high pressure on the tyre walls as they can be damaged. Well if they can do this to rubber, think what they could do to a thin sliver of paint if you get too aggressive.
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
The slightest stone chip can allow pressure washer water to get underneath the surrounding area, or as suggested crap preparation before painting.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
The door mouldings on mine are suffering the same,, I assumed they had never been primed correctly, spraying onto plastic is not the same as spraying onto metal. 2010 RRS, TDV8
Graham Hunter Member Since: 31 Jul 2020 Location: Leeds Posts: 2 ![]() ![]() |
Thanks all. I’ve spoken to 4*4 in Leeds and they pretty much told me the same. The paint won’t peel if a good primer is applied. In this case, I’m straight back to the plastic once the gold paint peels. Poor prep seems to be the issue. I was also advised that jet washing should be fine if the paint is properly put on the vehicle in the first place!
